Tight Spot on new chain and sprockets
Re: Tight Spot on new chain and sprockets
Postby steelsey » Sat Oct 06, 2012 5:52 pm
Hhahah The sprockets were box fresh :lol: I'm waiting to hear back from Renthal, I so hope it's a dodgy sprocket.... Actually I might try un-dooing the sprocket bolts to adjust the sprocket a tad in the opposing direction to the tight spot and see if that elevates it at all.
Postby steelsey » Sat Jan 12, 2013 9:44 pm
I'm so sick if this! I now have another new chain and new sprocket with the same problem! The tight spot occurring in the same place on the rear each time! Could the Cush drive have anything to do with it? Or carrier bearings? Sod it i might just fit some new bearings to the carrier too!
Postby snoopyjon » Sat Jan 12, 2013 11:46 pm
I wish I could offer some advice, but I haven't got a clue :( Certainly sounds like something needs sorting out though...! Good luck with it and fingers crossed you get it sorted soon :thumbup:
Postby sparkysp2 » Sun Jan 13, 2013 8:52 am
Are you using a soft link when joining the chain?
Postby steelsey » Sun Jan 13, 2013 9:23 am
Yep, the one supplied with the chain...
Postby sparkysp2 » Sun Jan 13, 2013 9:41 am
How many newton metres did you apply to dome over the soft link ?
Postby steelsey » Sun Jan 13, 2013 10:42 am
I don't know! It's the DID ZVM x 2 chain that has a hollow pin and I use a whale tool so you just leather it with a hammer until the head is flared to the correct spec
Postby sparkysp2 » Sun Jan 13, 2013 1:50 pm
Sorry to keep asking questions mate but where is the tight spot?
Postby steelsey » Sun Jan 13, 2013 2:38 pm
It occurs in the same place on the rear sprocket! I marked it, rotated the wheel and each time the sprocket returns to the same postition the chain goes tight! I'm wondering it could be the bearings in the sproctet carrier now!
Postby sparkysp2 » Sun Jan 13, 2013 3:12 pm
Also check the rear sprocket on a flat surface make sure that is true as well..
Users browsing this forum: No registered users and 13 guests
