pc3 accel pump....
pc3 accel pump....
Postby VVTR » Wed Nov 14, 2012 4:22 pm
anybody else tried running the accelerator pump feature on their pc3???
http://www.powercommander.com/downloads ... orPump.pdf
i stuck it on mine (5 min job) and could definately feel a difference in throttle response on quick launches.
just running the default settings though - anyone had a play with it proper and had good results?
can't say ive noticed much difference in fuel economy either :thumbup:
if you havent tried it - download the accelerator pump utility from pc webby, plug the lappy in and run pc3 program, click get map and save your current map.
run the accel pump utility and click enable.
check your map is still loaded.
done - enjoy! :thumbup:
might be an idea to share maps too if you've had yours on the dyno?
im running a base map for akro system with flapper mod, with a few tweaks to get rid of lean spots.
really nice smooth map for my motor - you're welcome to give it a run if you're on a default map :thumbup:
VVTR
Re: pc3 accel pump....
Postby snoopyjon » Sat Dec 08, 2012 2:46 pm
I have just come back from my first runs with the PC3 on the bike. Wow, how much smoother?? I'm sure it was quicker too!!! :D :thumbup:
After the first run without the Accel Pump enabled, I enabled it, and set it to 75% sensitiviy, 20% extra fuel for 20 revs and went for another run. Can't say I noticed much difference to be honest, has anyone got any settings for the pump that they think definitely make a difference?
Users browsing this forum: No registered users and 6 guests
