Indicators
Indicators
Postby Jayboy » Mon Mar 19, 2012 8:51 pm
Got some strange stuff going on, when I bought the bike it had resistors fitted to the indicators, I changed all the wiring, removed them as I also changed the indicators on the back, and ended up with an overly-fast flash rate.
So tonight I went to re-install the resistors and I thiknk I've fried the relay somehow...???
The front indicators are the oval flush ones - uinknown bulb rating, rears I have just replaced with Honda pattern ones with cleaer lenses, a la 2006-10 Blade - also unknown wattage.
What's my best option - will an uprated LED suitable flasher relay sort this out, or should I get a new original-type and some more idiot-proof resistors??
:D
Re: Indicators
Postby Jayboy » Tue Mar 20, 2012 1:39 pm
ok, found out these are the resitors....
http://www.ebay.co.uk/itm/250587571027?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
where's the bloody fuse? save me trawling 500 pages of the manual!
Re: Indicators
Postby 5parkyuk » Tue Mar 20, 2012 3:20 pm
I just fitted am led relay , don't like the idea of resistors getting hot lying around ?
Dunno if you can mix and match led and filament :think:
Re: Indicators
Postby steve p » Tue Mar 20, 2012 6:30 pm
5parkyuk wrote:I just fitted am led relay , don't like the idea of resistors getting hot lying around ?
yes you can mix LED and filament if you use an LED relay, it really is the best way. They electronic LED relays work independantly of the load through them so flash at a constant rate! In this case you can remove the resistors.
Re: Indicators
Postby Jayboy » Tue Mar 20, 2012 7:13 pm
Ah, that sounbds like what I need, hoping - in a funny way, that I've just blown the relay. Don't like the idea of the resistors too much either, but didn't know if they only mattered while indicators were functioning or not?
Anyway - any ideas where from quickly - or a link, or a range, like Bikeit, Motrax, Oxford etc?
Re: Indicators
Postby Jayboy » Fri Mar 23, 2012 10:05 am
Right, daylight, managed to have another look and somehow the resistors have popped the fuse, so not quite sure how, so I am off to get one of these after I replace the fuse and get SOME indicators working - allbeit too fast...
http://www.ebay.co.uk/itm/MOTORCYCLE-LED-INDICATOR-RELAY-OEM-HONDA-FLASHER-UNIT-/350302785466?pt=UK_Motorcycle_Parts&hash=item518fac4fba
Re: Indicators
Postby 5parkyuk » Fri Mar 23, 2012 10:23 am
Looks the same as the one I have :thumbup:
Should be fine after fitting it. :character-beavisbutthead:
Re: Indicators
Postby Jayboy » Fri Mar 23, 2012 11:03 am
Good, that's what I wanted to hear... ps, just remembered paypal - again.... will do tonight for you bud..
Re: Indicators
Postby 5parkyuk » Fri Mar 23, 2012 12:12 pm
lmao ,Had given up and forgotten it .
Btw throw up some pictures of those indicators ,I want to see what they look like. :)
Re: Indicators
Postby 5parkyuk » Wed Mar 28, 2012 10:37 am
BUMP
pictures Jay ?
Nm papyal ,ive given up on that :lol:
Users browsing this forum: No registered users and 7 guests
