Power Commander 2 Q!
Postby ktm123 » Mon Jan 16, 2012 12:34 pm
Does anyone have a PC2, and can tell me what the little black wire is for?
I have just bought one but the wire looks too short for a battery wire. I know where all the plugs go.
Cant find any manual on the Dynojet site, their all for the USB and new V.
Thankyou.
ktm123
Re: Power Commander 2 Q!
Postby Sppete » Tue Jan 17, 2012 8:01 am
Is it a thin black wire on its own?
I've got a PC III USB and it's an earth lead on that.
Postby big stink » Tue Jan 17, 2012 9:30 pm
If its got an eye connector on the end its the earth wire. Mine is earthed directly on the battery.
Postby ktm123 » Sat Jan 21, 2012 9:05 am
Ta, got it fitted, it was the earth wire.
But....
When I connect the PC the FI light flashes, when I disconnect it the FI light goes back out???
Also I cant get to load a new map, its saying Com Opened But Power Commander Not Found?
Anyone else got a PC2 fitted and any help getting a map on to it?
ktm123
Postby Sppete » Sun Jan 22, 2012 5:39 pm
That doesn't sound good. Is the PC new to you? Have you seen it working before? A flashing FI light indicates a fault, depending on the number of flashes it should indicate where the fault lie's. I'm thinking the PC might be dragging down one of your suppy lines :think:
Postby ktm123 » Tue Jan 24, 2012 5:49 pm
It is being sent to DynoJet for them to check the unit. Thanks.
ktm123
