rear wiring
rear wiring
Postby 5parkyuk » Fri Jan 13, 2012 11:58 am
Can someone post a pic of thier sp rear showing how it routes ,cheers.
reason for asking is one of my rear light cables looks short :o
Re: rear wiring
Postby Jayboy » Fri Jan 13, 2012 1:55 pm
Think I'll be doing this tomorrow too... so I can post a pic. Mine was bastardised with an undertray & lights too which I'm taking off for standard stuff.
Re: rear wiring
Postby 5parkyuk » Fri Jan 13, 2012 2:14 pm
Same here ,but the offside rear light plug looks short :?:
Re: rear wiring
Postby Jayboy » Fri Jan 13, 2012 5:50 pm
I've given in and bought another loom to chop the plugs from...
I will pm you.
Re: rear wiring
Postby scottbeem » Mon May 21, 2012 8:58 pm
The wiring in general on the SP1 is shite, a complete after thought, an appalling harness bound together with insulation tape :? WTF when the plumbing is so brilliant!. Mine is currently stripped down and been restored to original spec. Do not think i will be buying another harness, one shitty one is enough. Soldering iron, solder, cable and heat shrink sheathing, all available off the shelf at halfords. The alarm is coming off too. More bollox.
scottbeem
Re: rear wiring
Postby scottbeem » Tue May 22, 2012 9:02 pm
Errr, on closer inspection a lot of the insulation tape was put on when the alarm was spliced in, What an unholy feckin mess mine is, a breakdown waiting to happen. May have to buy another harness :oops: I take back my slur of Honda electricals :)
scottbeem
Re: rear wiring
Postby 5parkyuk » Wed May 23, 2012 6:45 am
HAHA mine was the same, spent a bit of time re-soldering and heat shrinking , you'd never know now. :D
