K & N Air Filter and Power Commnader
Postby 100bore » Mon Apr 11, 2011 10:15 pm
Hello all,
As they seen to be fairly universal modifications, I'd be interested to hear peoples opinions regarding the fitting of K & N air filters and/or power commander.
My recently purchased 2002 SP2 is running standard exhausts and has,I believe had the flapper valve removed.
Thanks
I
100bore
Re: K & N Air Filter and Power Commnader
Postby tonto sp1 » Tue Apr 12, 2011 7:23 pm
I have both k+n and pc3...cant say i,ve noticed a difference with the filters.....but the pc3 made a big difference to the rideability of the bike :thumbup: ..not a big power gain but smooths out the snatchy throttle and get a few more mpg as well :thumbup: ..another cheaper mod to consider would be -1 tooth front sprocket from 16tooth to 15tooth, has a similar effect to p/c...sp,s have a really over tall first gear and the sprocket mod makes the bike more responsive :thumbup: ...but be aware the sprocket mod will slightly alter speedo readings :? ...
tonto sp1
Postby Dmac » Tue Apr 12, 2011 9:46 pm
Hey there,
I had the filters, pipes and PC3 on my SP2, They were on it when I got it. I put it back to standard and sold the goodies.
To be honest they wern't my thing anyway, but I don't notice much diference apart from the soundtrack :!:
These things are fairly quick to begin with, for road riding I don't miss them.
The SP1 has different injectors and throttle bodies so it is a different set up. I think they are more benifical on the SP1. :geek:
If it was me, I would I would consider the sprocket change Tonto mentioned and spend the money saved on petrol and Jameson. :D
Postby Stars and Stripes » Thu Apr 14, 2011 12:50 pm
Hi I agree with goose, I have P.C and K&Ns also with the gearing change, I also have a quarter turn throttle (makes it interesting) all the mods work together well
Paul
Postby 100bore » Thu Apr 14, 2011 7:53 pm
Thanks for the replies. :thumbup:
I will definitely think about the gearing mod. I agree that 1st gear seems very tall. I might try 3 extra teeth on the rear, rather than 1 less on the front, as I'm led to believe that this will wear the chain less. :geek:
Anyway, thanks again.
I
PS: Stars and Stripes, where did you get your quarter turn thottle?
100bore
Postby Dmac » Sun Apr 17, 2011 8:52 pm
You are right about the smaller sprockets wearing faster, they also wear the chain more as the links have to run the tighter radius of the smaller sprocket. :thumbup:
I haven't tried this but will your chain be long enough to go around the 3 tooth extra rear sprocket?
Postby 100bore » Tue Apr 19, 2011 5:10 pm
You could be right Dmac. Better try the smaller front sprocket, methinks. :idea:
Ta
I
100bore
Postby Stars and Stripes » Tue Apr 19, 2011 9:33 pm
100bore wrote:Thanks for the replies. :thumbup:
I
It was fitted to the bike when I bought it plus loads of other mods!!!!!
Postby Strappy » Fri Apr 29, 2011 9:00 pm
Ta
I
Or go -1/+2 and stick a 190/55 tyre on the rear :whistle:
Tough on mime, tough on the causes of mime.
Strappy
Postby 100bore » Sun May 08, 2011 8:19 pm
Well, in the end I didn't bother with K&N's but, have fitted a PCIIIusb (loaded with the European stock map) - smoother power delivery and better mpg - and 15t front sprocket. :thumbup:
The smaller sprocket makes an immediate noticable difference. By my calculations, I think my speedo now over reads by around 7%. Is this other peoples' experience?
100bore
Users browsing this forum: No registered users and 11 guests
