What has been done?
What has been done?
Postby Neil McClure » Sun Dec 22, 2013 9:00 pm
Ok guys here are a few pics of what I have done so far, can you guess or tell what the mod is?
Ok that is enough for now but more to follow if you guess these correctly.
Re: What has been done?
Postby Jacktad1971 » Sun Dec 22, 2013 9:43 pm
No idea fella but it looks quite technical and interesting! I am guessing it will involve something with making adjustments to the engine management system :?:
Jacktad1971
Postby nobody » Sun Dec 22, 2013 10:38 pm
I see Samco/front mount rads, I also see a stick coil mod and a hand brake guard...
nobody
Postby Stars and Stripes » Sun Dec 22, 2013 11:06 pm
Will the Rads get any protection?? They look great
Postby Sppete » Sat Dec 28, 2013 1:59 pm
Okay, I'll go for the obvious
1) Race rads and s/steal brake hoses
2) Coil sticks and Pair block off plate
3) GP brake lever protector and carbon frame protector
Postby Neil McClure » Sun Dec 29, 2013 5:23 pm
1. Front rads and silicone hoses.
2. Coil stick and pair blanking plate.
3. Front brake guard which is compulsory next year.
and here is a couple of other mods.
Postby Sppete » Mon Dec 30, 2013 6:51 pm
Under slung rear brake
Bobbins
Harris exhaust ( and is that an Ohlins shocker hidden back there?)
Rear sets
And what make are those wheels?
Brembo front stoppers.
The forks look like the standard legs from that pick. Have you just re-valves them and fitted oil and springs to match?
Postby N11 EXPRESS » Mon Dec 30, 2013 7:43 pm
Abs? I see the yokeys on the disc
Postby Neil McClure » Mon Jan 06, 2014 8:24 pm
Underslung captive bracket and wide track disc.
Harris HL cans.
Pulse ring for IRC traction control.
More pics soon.
Postby Sppete » Tue Jan 07, 2014 8:40 am
Traction control? :shock:
:clap: That's the first SP I've seen with it on. Have you had a chance to use it in earnest yet? Or is it more of a "just in case" item ?
Pete.l
