Started putting my SP1 back together
Postby hanberg » Tue Feb 14, 2012 10:56 pm
Finally started putting my SP1 back together efter a thorough cleaning. SP2 swingarm is on, and Ive begun fitting the wire-harness.
Re: Started putting my SP1 back together
Postby SubSailor » Wed Feb 15, 2012 3:59 am
On the last photo, it's good to see you have proper technical documentation on the far wall. :thumbup:
Postby Sppete » Wed Feb 15, 2012 1:31 pm
Nice chassis :thumbup:
and the bike not too bad either
:lol: :lol:
Postby Dmac » Wed Feb 15, 2012 6:34 pm
Thats looking good Hanberg! :clap:
Like the SP2 swingarm and love the home made stand's :thumbup:
Postby hanberg » Thu Feb 16, 2012 9:42 pm
More photos
But damn I hate fitting wires. Everything looks so nice a neat until you start putting on the harness.... Id love to make my own, but dont think I have the patience
Postby GOOSE_SP2 » Wed Feb 22, 2012 5:13 pm
Sorry to divert but is that a VFR lurking in the background?
Postby hanberg » Wed Feb 22, 2012 8:39 pm
Actually two old VFR RC36-1 and a Triumph 955i - none of them are mine though.
Postby steve p » Wed Feb 22, 2012 10:21 pm
Nice, tidy undertray in the making, Not sure that you should mount the regulator/ rectifier unit so close to the ECU though as it usually uses the sub frame as a heat sink and gets very hot, too hot to touch close by! It may be ok but i would mount it well back from the others, just a thought.
Postby SubSailor » Thu Feb 23, 2012 1:56 am
He could replace the OEM rectifier/regulator with a Shindengen FH012AA MOSFET type rectifier/regulator as used on current bikes.
Physically smaller, and runs much cooler. Will need an adapter harness to mate the different connectors, but those can be had in kit form.
Postby hanberg » Thu Feb 23, 2012 7:09 am
My friend with the Triumph is already looking at those, the Viffers run fine, so dont think it would matter.
It is a bit close, but there is 10mm air on the mount side of the rectifier, as it put the riv-nuts in from the "wrong" side to make some room.
