SP1.5 Road and track
Postby Neil McClure » Thu Nov 20, 2014 3:23 pm
Hi all, Ive put this up for sale at the mo, may break it if it does not sell.
Re: SP1.5 Road and track
Postby Sppete » Fri Nov 21, 2014 8:02 am
Should have add this to it Neil. I saw it earlier in the week and wondered if it was from any of us
HONDA VTR1000 SP1 SP2 RC51 HRC ROAD AND TRACK. Selling my Cabin SP1.5 track bike. I converted from a standard road bike with V5 in my name, all chassis and engine numbers intact so could be put on the road as is with only a number plate mount, brake light and horn needed I could do this for the winning bidder if wanted. The bike spec is: registered 10/07/01, SP1, SP2 swing arm with paddock stand forks and QUICK RELEASE rear wheel mod and AP RACING underslung captive caliper for wide track rear disc, front radiator and oil cooler kit fitted, CORSE slipper clutch, engine less than 7K miles, front BREMBO RACING calipers, BREMBO RACING discs, SP1 forks, race top yoke, BREMBO clutch and master cylinders, keyless ignition bar switches, race clip ons, gear position indicator, HRC rad catch bottle on snorkel, flapper and diaphram removed, HARRIS fairing bracket, SPRINT steering damper, PC3 and CORDONA GP load cell QS, HARRIS quick filler, HRC tank breather, HONDA coil plugs, race wiring loom, rear sets with integral reservoir, OHLINS rear shock, SP1 & SP2 wheels, 520 X ring chain, SP2 rear subframe modified to take race only kit, race battery, HRC QA throttle, all steel spacers changed to ally incl. internal wheel bearing spacers, HARRIS exhaust on standard headers. If no sale then I may part out after listing. On recent Eurotrack day it sat below 74deg when newer ZX10Rs were coiling over also managed a 2.00.4 lap. Any questions text Neil --------------. Collection only or would deliver for cost of fuel in UK only.
I took your mobile number, out just in case, there's nutters out there :shock:
Postby Neil McClure » Fri Nov 21, 2014 9:16 am
Thanks for that.
Postby Stars and Stripes » Fri Nov 21, 2014 9:20 am
I saw it too, but arent we all nutters on here?????
Postby sp1Dave » Fri Nov 21, 2014 6:23 pm
How much for the rear ohlins shock
Postby AdamSP » Sat Nov 22, 2014 12:05 am
Hi Neil, I would be interested in the brembo calipers, ap caliper and mount and radiator ,oil cooler if you break the bike. Regards Adam.
AdamSP
Postby Neil McClure » Tue Nov 25, 2014 8:52 am
Hi guys guide prices if i break it. Let me know if your interested in any parts.
Part prices excl. postage.
SP1 frame & v5 £600
Engine c/w slipper clutch £600
SP2 swingarm c/w quick release & captive AP caliper & paddock stand forks. £300
Brembo race calipers
40mm caliper brackets c/w unused pads. £600
Harris fairing brkt. £50
Harris fuel cap. £30
Thermae front rad kit & stat mod & oil lines £525
Samco hoses. £75
Coil sticks & plugs £40
Complete body work inc tank c/w pump £500
Race rearsets c/w integral Brembo rsvr. £150
Ohlins H0204 shock. £300
PC3 & Cordona gp QS. £300
Sprint steering damper. £125
Forks. £300
Race yokes. £100
Race wiring loom & switches. £50
Brembo m/cs. £225
Race clipons. £30
Clocks £150
Snorkel £100
Throttle bodies. £75
Air box £25
SP2 race subframe. £100
Brembo race discs. £225
SP2 sows £350
SP1 wows c/w discs £350
Harris slip ons. £250
Standard headers. £100
Postby AdamSP » Tue Nov 25, 2014 4:42 pm
Still interested in calipers front and back. If you break the sp. regards Adam.
AdamSP
Postby brisp2 » Tue Nov 25, 2014 5:45 pm
Hi neil, I would be very interested in the swingarm,caliper,paddock stand forks.
regards reggie.
brisp2
Postby pirks » Tue Nov 25, 2014 9:17 pm
P.m sent regarding rear shock
