Is that complete?
Can I sell it,as a unit?
Screaming Chief wrote:PCIIIr wasn't a USB version, it was a serial/rs232 (ie a 9 pin) the same shape as your old style VGA monitor connection
So to use it on a pc/laptop, you either need an older pc (since most nowadays only have USB or HDMI connections) or the buyer would need to get a cable to convert the 9 pin out to USB, which you can get from Amazon/PCWorld/Maplin etc.
http://www.amazon.co.uk/Max-Value-Seria ... 131&sr=8-7
Can't tell due to the angle, but looks possible that the connector that screws to the negative battery terminal might have snapped off (either that or its bent over ?) but that's obviously fixable.
Plus you either need the software cd, or a download link.
5parkyuk wrote:Chalkie ,sell it to meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
