Clutch circuit breaker/maker?
Postby hanberg » Sun Dec 04, 2011 10:10 am
Does the contact(?) on the clutch on a SP1 make or break the circuit when engaging the clutch? Thinking of removing it, will be fitting another M/C later anyways which doesnt have it.
Re: Clutch circuit breaker/maker?
Postby N11 EXPRESS » Sun Dec 04, 2011 8:49 pm
as far as i know its just for stopping ya starting it in gear
Postby hanberg » Sun Dec 04, 2011 9:15 pm
I believe its there so you can start in gear if you pull the clutch. But need to know if I remove it, if the wires need to be joined, or not. Because it would suck not being able to start it in the new year when everything is back together.
Postby SubSailor » Mon Dec 05, 2011 3:55 am
The clutch switch contacts are normally open.
The contacts are closed when the clutch lever is squeezed to disengage the clutch.
Postby hanberg » Mon Dec 05, 2011 8:36 am
Thanks a lot, Ill just remove it then.
