Honda SP1 Gear..."Stick-POLE-Thingy!! URGENT.
Postby CHALKIE » Mon Oct 10, 2011 5:23 pm
Coming home from work tonight,I flicked up from 3rd-4th and my gear "thing",came off. :shock: :shock:
This bolt had come undone:
Question is; Should it be attached to a nut,the other side?
I managed to get home and tighten it with toolage,I'm wondering if I'm missing a nut?
I need to use the bike tomorrow. HELP.
Who needs a 16k redline?
CHALKIE
Re: Honda SP1 Gear..."Stick-POLE-Thingy!! URGENT.
Postby steve p » Mon Oct 10, 2011 8:25 pm
Hi Chalkie, its called a rose joint, you just need to use a bolt with a washer against it and a washer on the other side against the rearset frame so that only the inner part of it is clamped. Nut used as necessary :thumbup:
Postby Sppete » Tue Oct 11, 2011 7:49 pm
Oh yes!
It's a common problem with rear sets. I suggest you take them off and give them to me. Give me a little cash too and I'll let you have my OEM in exchange :whistle: :whistle: :whistle:
Postby CHALKIE » Wed Feb 22, 2012 7:19 pm
It happened again & this time I lost the nut. :(
I've managed to find a suitable nut,for now,but I'll be forever worrying it'll fall out again,(comes in three's!!) :x
Anyone else with aftermarket rearsets had any issues/problems/solutions? :?:
CHALKIE
Postby Dmac » Wed Feb 22, 2012 7:32 pm
Thats a pity Chalkie,
You could try using some threadlock on the bolt when you stick it back together.
It's like a super glue for nuts and bolts. Might do the trick.
There are also nylock nuts, They have a little blue ring of nylon arount the nut and this helps to stop them vibrating off.
Hope you get it sorted :thumbup:
Postby CHALKIE » Wed Feb 22, 2012 7:55 pm
Dmac wrote:Thats a pity Chalkie,
That's the thing mate. Does it need to be flexable or not? Is threadlock "flexable"?
I hate things going wrong on my WSB. :mrgreen:
CHALKIE
Postby Dmac » Thu Feb 23, 2012 6:07 pm
Hi Chalkie,
No the thread lock is not flexable, But that nut and bolt can be done up tight.
The movement is allowed for as the bolt goes through a small rose joint. If you look closley you can see the bolt goes through whats like a ball bearing with a hole for the bolt. The ball bearing can move about in the housing - also known as a spherical braring. Have a play with it and you should be able to see what I mean. sounds more complicated than it is.
