Inner faring
Inner faring
Postby spiv » Tue Sep 20, 2011 6:34 pm
OK ... tried to take the faring off t/day. The 2 bolts on the inner faring are just rotating & not undoing . Probably rusted . Tried penetrating stuff but no go. Any sugestions?
Re: Inner faring
Postby N11 EXPRESS » Tue Sep 20, 2011 8:22 pm
do you mean the v cowl martin?
Re: Inner faring
Postby spiv » Tue Sep 20, 2011 9:07 pm
The black one behind the front wheel. Has 2 bolts at the bottom attatched to lower faring.. pain in the ass!
Re: Inner faring
Postby SubSailor » Wed Sep 21, 2011 1:10 am
Those are rubber well nuts similar to ones used on the windscreen.
The bolt is probably corroded onto the brass insert of the well nut.
It may be possible to fit an extra pair of hands in there with a pair of pliers to hold the well nut and loosen the bolt.
Re: Inner faring
Postby steve p » Wed Sep 21, 2011 4:30 am
agree with that, plus you can remove the whole bottom fairing and v cowel as one to get to the well nuts easier.
Re: Inner faring
Postby snoopyjon » Wed Sep 21, 2011 8:54 am
What they said :text-yeahthat:
I had the same problem, but with only the one fastener... So I was lucky I already had one side off and could get pliers on the back of the seized one quite easily...
I need to buy some new ones, as I just re-applied the 'damaged' one, now I know how to get it off easily...
Thanks,
Re: Inner faring
Postby spiv » Wed Sep 21, 2011 5:42 pm
Thanks all :thumbup: .I will try the pliers first and if that fails ,I'll just take the faring off in one piece.
Stupid well nuts :thumbdown:
