Tank breather
PostPosted: Fri Jul 31, 2015 8:53 am
by zxrob
Hi Guys
I have recently purchased a tank for the sp that has a connection on the top for a tank breather/vent
It is basically a threaded insert that goes in a hole in the top of the tank
At the moment its loose and needs fitting in, I was looking at getting a matching nut to go inside then screw it in and seal it from the outside with some fuel proof sealer
Anyone used or seen a breather used on a sp before, I'd probably just bock it off
Cheers Rob
Re: Tank breather
PostPosted: Sun Aug 02, 2015 9:11 am
by Neil McClure
If it has a breather it has likely been a race tank. If you block it off you will vacuum lock your tank and stop the fuel flow. Post a pic to let us see the tanl.
Re: Tank breather
PostPosted: Mon Aug 03, 2015 11:30 am
My thoughts exactly,
but if you have a standard petrol cap it shouldn't need it unless the cap is blocked.
I also thought could it be to ensure the fuel can flow fast enough when racing and using high amount of fuel.
Re: Tank breather
PostPosted: Mon Aug 03, 2015 10:54 pm
by zxrob
Her you go
As you can see the hole is in the top of the tank, I will be using the petrol cap off my road bike, there are no other connections or gubbings there, I cant see why I cant just block it off
What ya think guys
Rob
