Different rear axle trouble!
Posted: Tue Mar 15, 2011 10:33 pm
Ho Hum!
I was out today for a good spin, got home and decided to check the chain tension.
It was slightly loose so, no prob, just loosen the axle nut and move the wheel back a little.
The nut was fairly tight, but after a few turns it wasn't getting looser.
Here's why
I had trouble with the front axle and caliper bolts too but got them out without damage, the cause? Loctite.
Whoever serviced the bike last had a tube of green super strength loctite and wasn't afraid to use it.
If I ever find them they will have to have it surgicaly removed
I am going to cut the glued on axle nut off and try to save the axle.
shopping list so far: LHS chain slider block, new axle nut and possibly a new axle. I have had the rest of the bike apart so there shouldn't be any more suprises
If I didn't have bad luck, I'd have no luck at all
Here's why
