Indicator problem
Indicator problem
Postby JohnD » Wed Jun 13, 2012 4:06 pm
So I bought some Bike It flush indicators for the front & some mini ones for the rear.
The front ones went on no problem, however the rear ones seem to double the flash rate - now I have never had this happen before with mini indicators !?:!?! :?
Is this normal for the SP rear indicators, or did I buy the wrong ones like a div?
Thanks in advance peeps!
John
JohnD
Re: Indicator problem
Postby sparkysp2 » Wed Jun 13, 2012 4:25 pm
if they are LED ones just buy an LED relay for a honda plugs straight into stock connector
Postby JohnD » Wed Jun 13, 2012 4:29 pm
No they are not LED, they are like these:
http://www.sportsbikeshop.co.uk/motorcy ... prod/74063?
J
JohnD
Postby sp1Dave » Wed Jun 13, 2012 7:20 pm
Change the rear bulbs for lower wattage one's and see will that work :thumbup:
Postby JohnD » Fri Jun 15, 2012 10:15 am
sp1Dave wrote:Change the rear bulbs for lower wattage one's and see will that work :thumbup:
Had a look and they are 10w bulbs which might explain it. If I stick 23w bulbs in there, then I'm guessing that should solve it?
JohnD
Postby sparkysp2 » Fri Jun 15, 2012 2:53 pm
Standard bulbs are 21watts mate......
Postby JohnD » Thu Jun 21, 2012 3:38 pm
yep 23w bulbs sorted it.
thanks
John
JohnD
Users browsing this forum: No registered users and 25 guests
