Flapper valve mod
Flapper valve mod
Postby Asherz86 » Sun Feb 20, 2011 10:18 pm
This should only be done to race machines and if it is undertaken hondavtrsp.com forum will not be held responsible for any malfunctions to the bike the valve mod is taken out on.
http://www.rc51.org/valve.htm
Leicester city!!! play offs here we come!!!!!
Asherz86
Re: Flapper valve mod
Postby wild01 » Mon Apr 18, 2011 2:11 am
:lol: I didn't do it, no body saw me do it, you cant prove anything! :shhh: :shifty:
Postby wild01 » Tue Apr 19, 2011 9:00 pm
Seriously, is this worth doing? Have you just done the tube removal and plug or have you done the full shabam? Did you notice any difference in either method?
Will
Postby Chip » Wed Apr 20, 2011 12:30 am
It takes a good chunk of weight and mess off the bike, but I can't say there's a big power gain to be had
Chip
Postby wild01 » Thu May 12, 2011 1:52 pm
Seriously guys, you need to do this mod! Bloody hell fire she sounds brutal now! I wouldn't say it's any faster at all but by hell the power delivery and breathing is so much better.
Kudos rating for this mod: As its free, reduces weight and makes the bike sound better than a roaring lion on Chrystal Meth 10/10!!! :clap:
I did it in a matter of minutes, follow the instructions for removal of diaphragm, solenoid and air tank as they are pretty spot on however the only thing I did differently was instead of buying the diaphragm cover cap I just replaced the existing diaphragm back in (obviously minus the flapper and hose). Again, I found a noticeable difference to the breathing of the bike resulting in a better power delivery right through the range but more noticeably at the lower end. Also a crisper, more intense roar from the bike which to be honest, gave me an erection!
8-)
Postby GOOSE_SP2 » Thu May 12, 2011 7:05 pm
Im always up for more noise! :thumbup:
Postby marra » Thu May 12, 2011 7:34 pm
wild01 wrote:Seriously guys, you need to do this mod! Bloody hell fire she sounds brutal now! I wouldn't say it's any faster at all but by hell the power delivery and breathing is so much better.
8-)
so what tools do i bring to the TT so you can do mine! :mrgreen: :thumbup:
Postby Sppete » Fri May 13, 2011 6:40 am
GOOSE_SP2 wrote:Im always up for more noise! :thumbup:
Hell!
I'm always up for an erection...where's that link?
Postby wild01 » Fri May 13, 2011 9:25 am
Its so easy mate, I think it was only a 8mm, 10mm, 12mm spanner/socket and a couple of cable ties plus 1 6mm bolt to block the throttle body air line, and a flat blade screwdriver to help push the hoses of the connections.
You have to undo the two RHS radiator bolts so you can create a bit of space to get in at the solenoid. The bracket that holds the air tank is one bolt to remove the tank but I took the whole bracket off to remove even more weight (a whole 20g lol!), The two bolts for that hold the starter motor in place so make sure you do them back up :D
Postby N11 EXPRESS » Fri May 13, 2011 1:15 pm
and for anyone in a hurry pull out the pipe and shove a screw in to it
