Cable clutch conversion
Postby pbc0 » Tue Oct 22, 2013 11:26 pm
My cable clutch using XL1000 Varadero sprcket cover & actuator pin.
[url][URL=http://s1127.photobucket.com/user/pbc0/media/sp%20engine/Honda%20SP1/photo_zpsc6bffdf2.jpg.html]Image[/url][/url]
[url][URL=http://s1127.photobucket.com/user/pbc0/media/sp%20engine/Honda%20SP1/photo_zpsc227dfa7.jpg.html]Image[/url][/url]
pbc0
Re: Cable clutch conversion
Postby turbo_billy » Wed Oct 23, 2013 4:19 pm
Looks a tidy job :clap:
What year/model were the parts off?
Postby pbc0 » Wed Oct 23, 2013 7:45 pm
It do'nt matter. They're all the same on the vara.
pbc0
Postby turbo_billy » Wed Oct 23, 2013 8:58 pm
Thanks :thumbup:
Postby steve p » Fri Nov 08, 2013 12:12 am
Looks neat, did you use the OEM rod and if so how much shorter or longer must it be?
Postby pbc0 » Fri Nov 08, 2013 4:33 pm
steve p wrote:Looks neat, did you use the OEM rod and if so how much shorter or longer must it be?
The vara control rod Is a straight swap.
The original can be cut down to 306mm.
It's made the bike feel much easier to control.
pbc0
Postby pbc0 » Fri Nov 08, 2013 6:47 pm
Grabby clutch is not an issue now.
pbc0
Postby steve p » Fri Nov 08, 2013 9:35 pm
Nice work mate i will look into it for next year :thumbup:
Postby Stan_SP1 » Wed Nov 20, 2013 2:19 pm
Nice work!
Did you HAVE to trim the sprocket cover like that or did you choose to do that for quick front sprocket changes?
Stan_SP1
Postby pbc0 » Fri Nov 22, 2013 1:45 pm
The cover won't fit straight off. You have to cut it down. I first just cut it straight across but it sits proud of the frame. This was the main reason for cutting it out. Sprocket changing was secondary but I do change the front sprocket sizes regularly & it is a faff you don't have to deal with anymore.
This is what you'll get before cutting down.
And after.
Theres an extended lip on the top side. I initially just cut a straight line from that lip to the bottom. The cver will then fit but I was'nt happy with the look.
I've cut it down again since.
Used the Cable & lever off an early Fireblade but have since changed the lever to a later Fireblade. 02 954 model because the brake levers are the same as the SP. So you can buy levers in pairs.
Only one minor issue is. Because of the snorkel, the radius of the clutch cable is a bit tight. Its well lubed & does'nt feel tight at all.In fact its pretty slick. But I reckon thats why Honda went with a hydraulic clutch with the banjo set at 90 deg. Because of the compact nature of the cockpit.
pbc0
Users browsing this forum: No registered users and 8 guests
