SP1 or 2 Jay, I've forgotten which you have.
Either way I'd go and find out your original settings and see if you are anywhere close. Its not often, unless you've had some mods done, it needs moving far off standard. If that's okay, I'd get the sag checked front and rear and once that's all done then if you still aren't happy wit it I'd start playing with spacers or dropping the front.
I've put some Hyper-pro springs in the front of mine and dropped the front by 5 mm. Huge difference for the better, much more planted and no bottoming out on ruff roads under heavy braking
Love em
