I cant be arsed with changing fans and stuff
http://www.redlineoil-europe.com/coolan ... er%5F00089
steve p wrote:yep Bobba, i tried Engine Ice last year and it didnt make any noticable difference or maybe just 1-2 degrees but not enough to spend on mate. Best thing is to take that bin liner off that blew onto your V cowel three years ago
steve p wrote:Be careful swapping the wires round as if you do it in the wrong place you put live down to ground and blow fusesYou have to cut the two black wires going to the motor on the fan itself and swap them there. Also its a good idea to turn the fan blades round as they are more efficient in one direction, this will involve spacing the fan legs off with washers otherwise the blades clip the rad.
I think I get itOberon Kenobi wrote:are you sure there's any point bobba?
Just playin devil's advocate, but I'm in London so slow moving sometimes and bike gets hot, but the fan cuts in a 103 and does its job just fine, temp drops and as soon as I'm on the move it plummets - bog standard coolant and standard fan and switch etc, might not be worth the hassle dude! or maybe just a lower temp thermo switch for the fan?
