Oil
Oil
Postby paulb » Mon Jun 20, 2011 1:52 pm
I am not sure when the oil was last changed on my SP1, he said it was 2k miles before I bought it so I want to change it to be safe. So what oil do you recommend?
P
paulb
Re: Oil
Postby snoopyjon » Mon Jun 20, 2011 3:37 pm
My last service, the guys put Putoline 10/40 Fully Syntetic in. I'd heard horror stories about fully synth, that it causes clutch slip etc, but I've not had a single problem. And Putoline only make oil for bikes, so you'd like to think they know what they're doing...
Re: Oil
Postby CXey » Mon Jun 20, 2011 4:37 pm
I only use fully synth motorcycle oil. Normally Mobil 1 which I believe is a 20W-50 though I could be wrong. Either way, if Mobil 1 is good enough for Lewis Hamilton..it's good enough for the SP!
I used to use Castrol but I get a cheaper deal on Mobil 1 through work 8-)
If at first you don't succeed, then sky diving isn't for you.
CXey
Re: Oil
Postby marra » Mon Jun 20, 2011 5:21 pm
snoopyjon wrote:My last service, the guys put Putoline 10/40 Fully Syntetic in. I'd heard horror stories about fully synth, that it causes clutch slip etc, but I've not had a single problem. And Putoline only make oil for bikes, so you'd like to think they know what they're doing...
as above :thumbup: and the same stories about fully synth
Re: Oil
Postby paulb » Mon Jun 20, 2011 6:29 pm
I was expecting everyone to say full synth, so there are conflicting opinions here too, I thought when we are all talking about the same bike that there would be a unanimous agreement on the full/semi debate.
paulb
Re: Oil
Postby Yermaun » Mon Jun 20, 2011 9:47 pm
Castrol Power 1 semi synth, use it in all my bikes :thumbup:
If you disagree with my opinion, feel free to ignore it.
Yermaun
Re: Oil
Postby wild01 » Tue Jun 21, 2011 3:38 am
I've used both of these in my SP1 2000 model:
Fuchs Silkoline COMP4 10W-40
Putoline Sport 4 10W-40
All I will say is, I'm a bit funny when it comes to oil change schedules and I do mine way more than required. It never hurts to change the oil, accept the wallet! Get some good deals on ebay with the filter too.
I've steered clear of the fully synth stuff, the semi is suitable enough.
Re: Oil
Postby Sppete » Tue Jun 21, 2011 7:05 am
Always been a Fuchs Silkolene Man but now I'm using Rock Oil. I was recommended it buy a local chap who builds race engines. Personally I can't tell the difference but I'm a little past an oil change now and I haven't burnt any nor has the level gone down or changed colour much so it must be fairly reasonable. On the other hand, maybe he just gets a good deal on it and can make some better profit :think:
Personally I don't think the make matters too much as long as you do regular changes. I do mine every 4k, I'd rather not wait until it's worn out or full of crap before it gets done.
Re: Oil
Postby paulb » Tue Jun 21, 2011 9:24 am
My local shop stocks rock oil, so I think I'll give rock oil semi a go and see how it works out
paulb
