Valve Clearances
Re: Valve Clearances
Postby mattymc » Sun Dec 16, 2012 1:00 pm
Ok, all clearances checked. I need to replace all of them, but all by roughly the same amount so I guess everything is wearing evenly. Most of the shims I need are 185 and 195, but I need a 188 and a 192 shim as well, do these size shims exist? If not what would be the best size to go for?
Matt
Honda SP1
MTC Exhaust
PCIII
mattymc
Postby Dmac » Sun Dec 16, 2012 3:08 pm
Hi Matt,
188 and 192 do exist and can be ordered from honda no problem, I think they are about £3.00 each :thumbup:
188 is actually 1.875 and 192 is 1.925 , they just round the size thats printed on the shim. :ugeek:
Can you get away with swapping some of the shims about so you don't have to buy as many?
I would go on the larger clearance side, So that as the valves recede into the head the clearances will still be good.
So if it is say .13 +/- 3, this gives you .10 to .16, so I would aim for .13 to .15 so they will stay in adjustment longer and not burn out.
Just keep a good note of what shim goes where and recheck after you change the shims as it is easy to make a mistake. Also make sure the valve timing is spot on as the cams will turn slightly as you tighten the caps down - check and double check :thumbup:
Postby Dmac » Sun Dec 16, 2012 3:21 pm
mattymc wrote:Ok, if I was to end up with a measurement like 194 in terms of a shim size, what would be better, a 195 or a 190 shim?
Matt
Assuming for the inlet valves,
If 194 gives you the base clearance, +/- .03mm then a 192 (1.925) will give you base clearance plus .015 so 192 gives you .145 just where you want to be, on the looser side of the tolerance.
Postby mattymc » Sun Dec 16, 2012 8:47 pm
Thanks for the help guys, I really appreciate it. Going to order all my shims from Honda tomorrow :D
Matt
Honda SP1
MTC Exhaust
PCIII
mattymc
Postby mattymc » Mon Dec 17, 2012 10:59 am
55 quid for 8 shims! I wasn't expecting that! Ordered the two odd sized ones from honda and getting the rest from eBay, less than 30 quid in total.
Honda SP1
MTC Exhaust
PCIII
mattymc
Postby Sppete » Fri Dec 21, 2012 5:10 pm
Phew!
But at least you checked them and found out for yourself they needed doing :thumbup: it could have been a lot more cash later on if you hadn't :shock:
Fancey doing mine now you've had a little practice? :D
